Good morning,
I'm going through the routine of getting a good print on some white static cling. As I read about this material, I can see that it is not the easiest material to work with. It goes from washed out with ink limits to fuzzy lines from pooling very quickly. Its hard to get that happy medium. I'm getting to end of things to try, the results are okay but I think they could be a little better.
One suggestion someone made was to do one print and then have the machine suck the artwork back in and go over it a second time thus allowing the first image to mostly dry. That way you are limiting the ink enough to get clean lines on each run but the second run will add more color. Makes sense to me.
Anyway - I'm on Flexi 8.1, basically I only use production manager. Does anyone know the procedure to have my printer do this?
