Click to Support Signs101 ...
The time it will take to change out that station shouldn't have an effect on the nozzles - unless you are going to take it out one day and put it back the next....
An hour would be a long time to do that swap even if it is your first time. If you are worried you could park the carriage over on the right and use a cleaning swab saturated with cleaning solution to lightly dab the nozzle plates a few times during the operation. Don't wipe just dab - like cleaning a stain out of carpet.
Thanks; with the machine now apart, it will be a bit of time before the replacements come in.
- What was supposed to be a simple clean up ended as discovering a junk maintenance station.
I have fashioned a tub of Mutoh Solution and suspended the head to about 1/16 inch without touching any of the head surface except to immerse it in the solvent.
Ahh - I didn't think that it was already apart - makes sense now. Worst case would be to slide the station back in there - plug the drains and fill it with solution - Sounds like you already have it worked out.
A long time ago I read a post about covering the print head with plastic wrap or aluminum foil, I can't remember which. To create a barrier to keep the print heads from drying out. Mind you I have NOT done this, but it sounded like a cleaver idea.
