How to release the printhead gs6000
lerscom
Hi does anyone know how can i release the printhead from the home position, i had a headstrike and the printer is giving me the 1136 error and will not boot
ellsmako
Do you see PAPER JAM in the display.
turn off printer
open front cover
slide print head to the right and away from jam
release paer level
cut off material where cutting groove is nead post heater
turn feed material backwards onto feed roll
close cover
power on
make sure Check paper light is on and the PAPER OUT LOAD PAPer is in the display.
then reload material.
I have seen where a printer was near a bright light source and the sensors were over loaded.
ellsmako
GS6000 erro codes
Epson GS6000 Error Codes
Maintenance Request Errors
MAINTENANCE REQUEST - 0001 - The CR scan pass counter has reached the specified value. MAINTENANCE REQUEST - 0011 - The RTC backup battery becomes exhausted.
MAINTENANCE REQUEST - 0111 - The date has not been set.
MAINTENANCE REQUEST - 0100 - The following two errors are occurring simultaneously, 0001 & 0011
MAINTENANCE REQUEST - 1000 - The following two errors are occurring simultaneously, 0001 & 0011
MAINTENANCE REQUEST - 1010 - The following two errors are occurring simultaneously, 0011 & 0111
Service Call Errors
SERVICE CALL ERROR - 1101 - Life end of the CR MOTOR
SERVICE CALL ERROR - 1125 - Carriage home position detection
SERVICE CALL ERROR - 1133 - CR MOTOR in position time-out error
SERVICE CALL ERROR - 1135 - CR ENC ASSY check error
SERVICE CALL ERROR - 1136 - CR MOTOR step-out error
SERVICE CALL ERROR - 1137 - CR servo parameter error
SERVICE CALL ERROR - 1223 - PF ENCODER ASSY check error
SERVICE CALL ERROR - 1225 - PF MOTOR in position time-out error
SERVICE CALL ERROR - 1227 - PF MOTOR step-out error
SERVICE CALL ERROR - 1228 - PF servo parameter error
SERVICE CALL ERROR - 131B - Head driver (transmission gate) overheat error
SERVICE CALL ERROR - 1700 - Print position error
SERVICE CALL ERROR - 1900 - HEATER CONT BOARD ASSY serial connection failure
SERVICE CALL ERROR - 1902 - Over Temp PRE HEATERS(64) on the HEATER RELAY BOARD ASSY
SERVICE CALL ERROR - 1903 - Over Temp PLATEN HEATER(64) on the HEATER RELAY BOARD ASSY
SERVICE CALL ERROR - 1904 - Over Temp AFTER HEATER(64) on the HEATER RELAY BOARD ASSY
SERVICE CALL ERROR - 1905 - Over Temp PRE HEATERS(64) on the HEATER RELAY BOARD ASSY
SERVICE CALL ERROR - 1906 - Over Temp PLATEN HEATER(64) on the HEATER RELAY BOARD ASSY
SERVICE CALL ERROR - 1907 - Over Temp AFTER HEATER(64) on the HEATER RELAY BOARD ASSY
SERVICE CALL ERROR - 1908 - An abnormal voltage of the heater on the HEATER CONT BOARD ASSY
SERVICE CALL ERROR - 1909 - Comms Failure HEATER CONT BOARD ASSY and SUB-B/C BOARD
SERVICE CALL ERROR - 1910 - Under Temp PRE HEATERS(64) on the HEATER RELAY BOARD ASSY
SERVICE CALL ERROR - 1911 - Under Temp PLATEN HEATER on the HEATER RELAY BOARD ASSY
SERVICE CALL ERROR - 1912 - Under Temp AFTER HEATER on the HEATER RELAY BOARD ASSY
SERVICE CALL ERROR - 1920 - HEATER CONT BOARD ASSY-SUB TANK SENSOR 1 failure
SERVICE CALL ERROR - 1921 - HEATER CONT BOARD ASSY-SUB TANK SENSOR 2 failure
SERVICE CALL ERROR - 1922 - HEATER CONT BOARD ASSY-SUB TANK SENSOR 3 failure
SERVICE CALL ERROR - 1923 - HEATER CONT BOARD ASSY-SUB TANK SENSOR 4 failure
SERVICE CALL ERROR - 1924 - HEATER CONT BOARD ASSY-SUB TANK SENSOR 5 failure
SERVICE CALL ERROR - 1925 - HEATER CONT BOARD ASSY-SUB TANK SENSOR 6 failure
SERVICE CALL ERROR - 1926 - HEATER CONT BOARD ASSY-SUB TANK SENSOR 7 failure
SERVICE CALL ERROR - 1927 - HEATER CONT BOARD ASSY-SUB TANK SENSOR 8 failure
SERVICE CALL ERROR - 1A23 - RTC analysis error
SERVICE CALL ERROR - 1A26 - RTC communication error
SERVICE CALL ERROR - 1A37 - Head thermistor error
SERVICE CALL ERROR - 1A38 - Transistor thermistor error
SERVICE CALL ERROR - 1A39 - Head error
SERVICE CALL ERROR - 1A40 - MAIN BOARD ASSY IC2 error
SERVICE CALL ERROR - 1A41 - Head rank ID input error
SERVICE CALL ERROR - 2000 - NVRAM error
SERVICE CALL ERROR - 2002 - SDRAM error
SERVICE CALL ERROR - 2003 - Boot program sum error
SERVICE CALL ERROR - 200A - Program loading error
SERVICE CALL ERROR - 200B - Internal insufficient memory error
SERVICE CALL ERROR - 200C - Servo interrupt watchdog time-out error
SERVICE CALL ERROR - 200D - System interrupt watchdog timeout error
SERVICE CALL ERROR - 200E - Unknown NMI
SERVICE CALL ERROR - 3000 - AC power shut-off
SERVICE CALL ERROR - FXXX - CPU-related error
1136 is carriage motor so it may be blocked
jhanson
By any chance did you try to unjam the printer while it was still powered on? You should always, ALWAYS clear head jams with the machine off and unplugged to avoid damage.
The head lock bracket is located on the top of the carriage rail. If you remove the top cover over the maintenance area, you can see it. Release it, slide the carriage out a few inches, and try to power on again. If you get the same error, chances are that the motor driving chip has been blown.
