How to set Cut Contour in Corel Draw 5x?
newcraftsing
Hello,
I know to set Cut Contour in Corel Draw 4x but can any body help me to set Cut Contour in Corel Draw 5x for Roland VersaCAMM VP-540. TO USE CUT AND PRINT FUNCTION. AFTER EXPORT THE FILE FROM COREL DRAW AS .eps.
I'll be very thankful to you
regards
The Big Squeegee
Long Time Member
Welcome from OK USA
I don't know the answer to your question. You might have better luck if you ask in the approprate forum. This is an introduction forum.
Mike_Koval
This should get you going...also keep in mind what jhill says
  • CutContour Swatch in Corel x5.pdf
