How to set the Graphtec FC7000 back to the factory default settings
Joe House
Sign Equipment Technician
FC7000Mk2 and FC7000 series:
1. Power off the cutter
2. Press and hold UP arrow key while power back on
3. Release Up key when shown "NAVRAM Clear Start"
4. Press F3 "HP-GL (w/inch)"<br />
** choose other may cause display none English menu
5. Press DOWN arrow to switch to YES
6. Press ENTER key to confirm
The cutter will reboot, before using, if using CorelDraw or Illustrator
change the command set to GP-GL. Press MENU >> NEXT twice >>
INTERFACE >> COMMAND >> GP-GL >> ENTER. Now its ready to use.
phototec
Joe, Thanks a bunch. I will try this.
Do you know good condition settings for Oracal 651 on the Graphtec Cutting Pro CF7000-75?
