SfSD
I currently use a CNC router to make backs and faces, nails to do the trim and bend by hand. This works but the volume and the time it takes is starting to be a problem. I have 2 questions:
- I would like a flexible channel letter bender. I do not need a heavy duty hard to program unit that is designed for massive capacity. I also do not need a light weight unit. So I think the Accu-bend Ace is too light weight, the Model 26 is about right. What other brands and models would work? I am cheap, and ideas about used machines?
- I am using nails on plywood to do trim cap. I would like to be trimcaping (spelling) faster. Would magnets help? How can I trim cap faster?
