Click to Support Signs101 ...
Alright I tried to pull them off the white hose to test, that is not happening, how did you remove the towers from the hose? Or did you find the hose and replace it all?
Do you install the old print heads and do a clean of the op PH, when done? Or would you put a brand new ph in test? I was not sure if the old PH would be totally clogged at this point or not.
