HP 5500PS Ink in Air Pressure lines...
Ken Smith
Have any other HP 5000 series uses seen ink in their air pressure lines behind the ink station? I'm assuming that this is not normal. I think the air bladder in my ink cartridge was pierced, and ink flowed back in to the air lines.
If this has happened to you, did you have any problems after draining the air lines and replacing the problem ink cartridge?
Thanks,
Ken
jens
jup, thats beause te bag is pierced. Make shure the ink does not go in to the pump.
Let it dry in to the tubing. And replace ink cartridge
