KingsofWraps
N.C.
Finally after 4 months it arrived, the printer is amazing! How is it working out for you guys? We are getting trained on it tomorrow for all basic features as well as white ink.
I absolutely concur... but one has to let them work their process through to determine if the printer is actually DOA/lemon, or can be fixed.Sounds like the people who you were dealing with were not super competent to work with. Like who would ever tell someone to clean encoder every day, that's just stupid.
For inks I can only say, always keep one full in the stock. Order a new one when you replace it. Same with printheads so you have one to replace when you need it.
They are 220v machines the range is 210 - 240v for protection purposes.Mine (800w) is sitting in a box. Our power line has been rated at 241v and will not be installed as HP will not accept that rating as it is beyond 240v? Seriously?
I hope you get to enjoy yours!
AS far as I have been taught, the [power line] spec allows up to 250v and you treat it the same unless the power voltage is actually under the amount needed. I have never heard of equipment being denied for being at that range. If that is not the actual case, then I guess I have been taught wrong on that one.They are 220v machines the range is 210 - 240v for protection purposes.
I'm just not used to less than 10% tolerance unless battery operated or is noted to require a special power source to be in the middle.All equipment is different our Multicam only has a 15v window.
Isn't 200-240v over 10% tolerance?I'm just not used to less than 10% tolerance unless battery operated or is noted to require a special power source to be in the middle.
If it is 220v, 198-242v is 10%. That is the talk but I don't write the checks, just the operator.Isn't 200-240v over 10% tolerance?
Time for a buck booster?
