HP 9000s printhead issue
cheez_cb
here we go,
am new to signs 101, and this is my first thread as well...I own an HP 9000s
never had a single problem with it, the print quality has always been sharp and clear. Two days ago when i was doing the daily maintenance I noticed that around the printheads there was some build up of ink and other particles that accumulate there over time.
So i removed the wiper frame/box compartment or whatever its called, in order to have room to acces the bottom of my printheads. I used some wiper cleaning fluid to remove the ink build up around the heads...it wasnt bad at all..dont think it had a ton of build up...but it needed to be cleaned to my judgement.
so then i put wiper box back and i ran a strong PH Recovery like i do every morning and my Magenta and Cyan have jets missing. I Print and I dont get solid reds or blues...i get white lines from the missing jets to the point i have to print high quality specially a vehicle wrap that i printed today.
Doesn't matter how many strong PH Recovery or wash printheads i perform, i still get messy prints.
I need your help guys, i have always taken good care of this printer idk why all of a sudden I clean the bottom of my printheads and it goes all wrong.
thanks
HulkSmash
Sounds like when doing that you might have broke an O ring. Check to make sure they're there sealing the ink tubes
cheez_cb
an "O" ring? i never touched or disconnected any of the lines..but lets say that is the issue. what steps do i need to take in order to see if they are sealing properly?
Bill Modzel
I'd invest in a "Printhead Nozzle Plate Cleaning Kit". It's a kit with a protective guard and pads that you soak with a bit of printhead cleaner and park the printhead on it for an overnight soak. I've maintained mine for 4 years with occasional use of this kit.
I think that you may have inadvertently plugged the jets by your hand wiping attempt. Thats not an acceptable way to clean the printheads on the 9000.
