culblaster
I am going to attempt to do this... printed out the sheet, found the .plt file. HP Cutter control software won't let me use (it's grayed out) its function to send the plt file to the cutter, so I'll try it with Flexi. This printout doesn't include a barcode so I presume it's a manual alignment method/manual prompting and reading... not sure how to do that yet.You can print the opostestv3.pdf (it's in the testfiles directory in HP cutter control) on a desktop printer, then send the pit file to the cutter. If this works, there could be a bug in flexi.
Sometimes the offset is wrongly registered. If you do the Opos calibration two or three times, it can help. (You can monitor the values in cutter control service mode)
