HP cutter issue reading registration mark #2
jimbug72
We have an HP 315 and an HP Latex 54 Plus Cutter using Flexi. When doing print/cut procedures, we occasionally seem to have an issue with the cutter reading the 2nd registration mark. Reads the barcode just fine, then reads the fist registration mark just fine but it will start to look in the wrong place for the 2nd cropmark. It's far enough off the mark that it will never find it (it starts looking about 4" or so above where the mark is.) Once we "forced" it to look in the correct place, but it when it started cutting, it was waaaay off of where it was supposed to be cutting.
As far as we can tell, it seems to be completely random, and thankfully not super common. Very frustrating though, especially when it happens on large prints.
Any ideas?
balstestrat
Problem Solver
Next time try to turn it 180° I think usually it makes the marks with standard distance say 15" but the last one can be less say 11".
Barcode should always turn it correct way but say you for some reason sent it manually from the cut queue it could be it.
Another is if you have it on a roll and autoload is turned off, then it doesn't unload it before reading the marks and could jump a little. Dirty grit rollers make it happen as well.
jimbug72
Thanks for the response.
We've tried flipping and loading it with the same result. We pretty much never put them back on a roll.
I don't think it's a feed issue, because it consistently overshoots the mark by about 4 to 5 inches, but the prints aren't distorted. It often happens on the second registration mark, but not always. The print that prompted me to post on Friday, the guy working on it tried clearing the cache in Flexi, then reloading the same file & had the same issue. He saved the file in another location under another file name, same issue. Removed some text in the file (not live text, but converted to outlines) and it ran without issue. What makes it even more weird, there were other files with the text, using the same original file but with different color setups that ran without issue. It happens when we use the barcode, or when we send manually from Flexi.
Might be worth mentioning that we design in Illustrator, print/cut from Flexi.
davideagles
Any ideas?
The issue is likely seems to be Flexi software misinterpreting crop marks—try re-calibrating the cutter and ensuring proper lighting.
