Hp fb700
Discussion in 'Flatbed Printers' started by cwb143, Sep 17, 2012.
  1. cwb143
    cwb143 Member
    304
    4
    18
    Oct 18, 2010
    USA
    How much are these FB700s anyway? Says they'll run 860sq ft hr but what does that really mean? what will it run in production mode quality?
  2. Hzone15
    Hzone15 Member
    97
    Production quality is over 200 sq. ft. Billboard mode is 800+
    It's a good printer, one step newer than the FB950. White option is a plus for some.
  3. Robert Gruner
    Robert Gruner Member
    288
    31
    28
    Mar 6, 2012
    houston tx
    FB700 is an excellent production UV printer. It is a hybrid model which simply means belt fed as opposed to flat table. Actually, if your work profile calls for printing various size flat stock, the hybrid is often a lot easier than a flat table.
    I would be glad to provide you references in the TX, OK area.
    Bob Gruner
  4. cwb143
    cwb143 Member
    304
    4
    18
    Oct 18, 2010
    USA
    Our company is headed to Atlanta to go look at it. Thanks!
  5. jasonx
    jasonx Very Active Member
    1,314
    24
    38
    Aug 5, 2007
    Australia
    Getting mine delivered tomorrow :)
  6. cwb143
    cwb143 Member
    304
    4
    18
    Oct 18, 2010
    USA
    I'd like to know how it goes. when you get it all going.
  7. jasonx
    1,314
    24
    38
    Aug 5, 2007
    Australia
    What would you like to know? I am running modes that give me 30 or 24 square metres per hour. Mainly on what you guys call coroplast. The N-UP Feature is cool because we are ordering in our sheets pre cut and printing full bleed.
  8. FishnSigns
    FishnSigns Member
    131
    2
    18
    Jul 14, 2011
    Littleton, Colorado
    We have been running our FB700 for 3 months now and couldn't be happier. Our standard mode for most projects is "indoor signage". For higher quality prints with large solid areas you may need to switch to "photo" mode. If you are printing text only, short term coro, run in express or billboard mode. The ink is very sticky on coro. We researched the heck out of flatbeds and made the right decision for our operation. Best of luck.
  9. jasonx
    1,314
    24
    38
    Aug 5, 2007
    Australia
    Have you had any adhesion problems or durability issues on coro? I've read alot of people sometimes can have issues (Not FB500/700 specific).
  10. artbot
    artbot Very Active Member
    3,164
    12
    38
    Feb 18, 2010
    Houston TX
    i've been jobbing out projects to an fb700 for the last two months. i can't speak to the coro, but the fb700 ink compared to all the flatbed samples i've come across is very delicate and has no solvent resistance whatsoever. my partner was preaching that he wanted an fb and i really feel like i dodged a bullet after working with fb output for the last two months. you have to handle it carefully. and the ink stinks for days. it must be a dual cure ink. because it is not at full cure coming off the printer. i had a freshly printed 4x8 sheet in my van for a day and i had do drive around with the windows down, and i can handle some pretty nasty fumes.
  11. jasonx
    1,314
    24
    38
    Aug 5, 2007
    Australia
    Hey artbot,
    I've read your post before. I have no smell coming straight off the machine. All the prints I've done are very scratch resistant I don't have to handle them carefully at all. These substrates have been coro, foamed pvc, comp panel.
    Here's a video of a scratch test with my finger nail. I can only remove ink if I basically scratch the coro like make an indent with the corner of my nail etc.
    http://videobam.com/iuDMk
    Was yours worse then this or at the same level?
  12. artbot
    3,164
    12
    38
    Feb 18, 2010
    Houston TX
    the print room that i pick up the prints from is fine. of course that room has a scrubber. when you pack up the prints and have them sitting in an unscrubbed room, that is when i can smell them outgassing for a few days. the scratch resistance, i'll have to do the same type of test with. all my parts are cut with either a track saw or a router. so the edges are fragile (not so with other inks). but what you are showing does make me think that my vendor isn't using enough UV. i've got some more parts being printed soon. i'll ask them if they are half dosing or what.
  13. jasonx
    1,314
    24
    38
    Aug 5, 2007
    Australia
    Cheers for that. I'll let you know in the future when I print onto a substrate I'm going to rip through with a circular saw and let you know how the ink holds up. Most of our work is display type work and cutting through it with a blade type cutter isn't an issue with the ink cracking etc.
    I did a pressure hose test also. From 2" + distance no problem. From less then 1" I could start to remove the ink. This was on coro.
  14. ForgeInc
    ForgeInc Active Member
    718
    Dec 7, 2010
    Portland, Or
    I replied to this before the site got hosed and lost a few days of posts...our prints have no smell whatsoever either. Only adhesion problems we run into is a bit of chipping when cutting acrylic or petg post-print, and if we use an adhesion promoter it pretty much solves it.
    speaking from experience our prints smell way less than vuteks, perhaps you can mess with lamp settings or the amount of ink that is getting layed down?
  15. SBTJC
    SBTJC Member
    25
    I dont notice the Offgasing until I go next door and grab a beer to bring back to the shop (of course only after closing) Then I still can't smell it, but I taste it. Its weird. You do need a good 24 hour cure on the Prints. Mine the print is fairly fragile up to about 24 hours, then its Rock solid.
  16. cwb143
    cwb143 Member
    304
    4
    18
    Oct 18, 2010
    USA
    I hear ya! I think we need some kind of ventilator. We found out the FB700 dosn't like thin material. say .015 or less. There simply isn't enough vacuum on a hybrid style printer. Its not as fast as I'd hoped. All said and done I think we are slower than we were but print nicer quality. It only has 12 print heads so the banding is bigger than I'm used to. It has alot of automation features that are good.
  17. ForgeInc
    718
    Dec 7, 2010
    Portland, Or
    Did you try printing shuttered vs non shuttered? It sometimes helps with our banding in black areas.
    We also had some weird banding issues we couldn't resolve when one of our machines had a vacuum issue. Once it was fixed, banding lessened.
  18. cwb143
    cwb143 Member
    304
    4
    18
    Oct 18, 2010
    USA
    Tried it. The glossier it gets the worse it is for just Solid 1 color or 2 color prints. Because we do alot of scree printing. We try to take on some of those jobs and they don't quiet look good as the screen prints. I believe just about anyone can digitally print photos but when it comes to artwork the lawnmower effect comes into play and then speed becomes an issue. Because you have to go up to a higher quality mode and that slows you way way down. But for small runs this isn't much of an issue but for large runs say 2 or 300 and more that is an issue.
