HP L25500 Rewinder Motor and Gears HELP
wakeshredder
I have an L25500 that needs the rewinder motor gears replaced. Someone pulled the spindle out from the left side only and it broke the plastic piece that holds the rewinder gear which connects to the spindle. That gear is metal with a plastic gear connected to it that is driven by the rewinder gear. I have all the pieces except for the plastic gear as it broke too. I don't have the pieces anymore so I wanted to just order an new Rewinder And Gear Kit. So, I did, and it is different. I used the specified part number, but it is a setup that would go on a small spindle like a z6100! This is frustrating, as I cannot seem to find the correct part anywhere! Any help would be highly appreciated.
