frojasferrari
The things is, it looks like the ink is not properly adhere to the phototex, I print, cut, and then lay on my cutting table to cut, but when you scrub de print with a white paper, the white paper ends with ink on it, ink from the print.(When installing is on your fingers)
Been printing a lot of things, vinyls, canvas, window perf, even bond paper, and phototex is the only one i have this problem.
Heres a video and a picture, so you can see i do not apply to much pressure on the print to get the white paper stained.
Video:
[video=youtube;hYrXoaEsEzw]https://www.youtube.com/watch?v=hYrXoaEsEzw[/video]
So.... its a temperature thing? (tried lots of combinations) Profile thing? (tried lots of profile, even done a special one for Phototex from scratch)
Anyone else having a similar problem?
Its not a big problem, from all the wall murals we have done, only two clients told us about having a problem with ink rubbing of the paper, but not a big deal for them (kind of worrying for us), because we know the problem is there. What do you guys think?
I was having problems cutting the overlaps a while ago, since then we simply dont cut the overlaps, but the problemas I was having was that when you cut the overlap you get to see the cut, is not "invisible" as it should be or as it is with other media we use. I was thinking that maybe it has something to do with the ink not properly adhering to the media.
Any ideas?
