HP L360 Maintenance Tests - How wide roll needed and best material to use?
cg2006
How wide of a roll and what is the best brand/substrate for testing calibration tests on the L360?
dypinc
HP recommends using SAV (self-adhesive vinyl) for printhead calibrations. It needs to be at least 36 inches in width.
Anything less than 54" will do smaller calibration targets and only read them once. 54" will allow bigger targets and reads each one three times.
If you don't trust the onboard calibration (which some of use are finding out to not work correctly) than 36" would be enough.
