Need Help HP L560 Error Code 25.16:10
bgraphix
Any suggestions of what to do in regards to the above error code? Has anyone ran into it before?
The screen said “Yellow slot ink level sensor overpressure or malfunction”
3 cartridges are now faulty due to this error. 1 it happened to last week and 2 today. I’m not sure if this was the error message the first 2 times, but it was for sure the last time.
Thank you in advance
Christian @ 2CT Media
It's a bad PIP, we had a ton of issues with it on our old 360... ended up being a damaged pin on the mech board. I'd call tech support and log a case if you are under warranty or if you can buy the part you can change it out in 30 mins or so. It took up 15 months to fix our printer completely
bgraphix
Unfortunately, our warranty has ran out. What exactly is a PIP?
Rogar
Industrial discussion to improve my industry
Please, you can check your printer driver/Installer is right version and setup perfectly.
TheYallaman
Hi Roberta,
Call the YallaMan. We can fix it. 4-4-451-5843
TheYallaman
Call the YallaMan. We can fix it. 404-451-5843
