10sacer
You should have looked at the CET FK512.
I have a 6x10 bed and 6 colors + 4 heads of dedicated white or you can switch to 2 heads of white and 2 heads of varnish if you so desire. Uses same heads as Oce/Fuji (Konica 512s) and has a 14 picoliter droplet and quality is outstanding. I print to acrylic almost every day and you do need to use the Optix digital grade acrylic for better ink adhesion, but I also use standard acrylic for static displays that no one is going to touch and it works fine, too. If acrylic is the issue - switch to polycarbonate.
To each his own, but there are always alternatives to whats out there.
