Our HP360 latex printer has been throwing an 86:01 code. It will not initialize unless you change it to start in diagnostics mode. When you run the scan axis test, the carriage moves a foot or so then shows an 86:01 error. I have tried the Carriage Lubrication test and I get a 42:?? error (can't recall the second set of numbers) - "current too high in the motor", which seems like the motor is working too hard to move the carriage. Here is what I have tried so far:
We lubricated the rails, as we have always done on a regular basis.
We checked the rails for any obstructions or rough places
The printer is overdue for Maintenance Kit #3, just FYI. I took the felts off of either end of the carriage and looked them over, cleaned them up, lubricated them and put it back together.
Removed the end cap and took the carriage completely off of the printer. Looked for anything out of the ordinary - saw nothing, lubricated everything again.
Looked over the wire tray to ensure the wires weren't getting in the way.
Had a service guy overnight a used but working scan axis motor and replaced that
None of these things helped (I tried after eash of the above steps)
I tried to update the firmware, even though the version we have is up to date, but it gets to 99% and stops - may try that again later after posting this.
I took some "fish scales" that we use to calibrate our laminators and measured the force required to move the carriage when powered down. It requires 7-8 pounds of force to move the carriage. When you turn the motor by hand when it is powered down, there is some resistance in the motor. I removed the belt and moved the carriage without any motor resistance and it seems pretty smooth.
I powered down our HP310 latex printer, which I'm told has a smaller scan axis motor, and it only requires 3.5-4 lbs. of force to move the carriage. I assume the larger motor is the reason for the extra force, but I'm not sure.
I removed the tensioner and checked the bearing in the pulley wheel. It seems to move freely but I oiled it to see if that helped.
None of the above is helping and I really need to get this printer back in action. Do any of you have any ideas for the next thing to try? I appreciate the input! I am going to order the Maintenance Kit #3 parts because we need to do that anyway, but I'm finding it hard to believe something in that kit is the problem.
