HP5500PS UV BELT Tension
jasonzapoli
Having problem with the belt on the carriage. Printer works fine. But when belt is moving the carriage back and forth on the print the little metal clasp that holds the belt together bounces on the frame and makes a awful sound. Haven't found any help on the web for replacement or a fix. Has anyone else experienced this problem?
Robert Boyd
It sounds like you need to get that belt replaced.
Lift the cover and look to see if there are black shavings
under the belt on the silver tray under the belt.
You can do it yourself - I paid to have it done
There are youtube videos showing you how to do it
search HP Designjet 5500 carriage belt replacement
jasonzapoli
I dont have any shavings of the belt. Is it possible it just needs the tensioner adjusted?
Billct2
Yes, it's possible it's the tension. The same videos would show you where the "tensioner" is.
