Thanks, do you use this and do you know if its available in the UK?Chemica Easyprint, Hotmarkprint...
I've just done a quick search and it seems very expensive, not sure I could turn a profit with that, I'll keep looking to see if I can get an reasonably price. Thanks again.It's French company, I imagine you should find it across the river as well.
I know it's good stuff and works on latex as well.
Is there a company in the UK that sells transfers? Then all you need to do is heat press. Much easier and faster than printing, contour cutting, weeding etc...I've just done a quick search and it seems very expensive, not sure I could turn a profit with that, I'll keep looking to see if I can get an reasonably price. Thanks again.
Thanks, I'll have a look at that, is it OK with latex?siser colorprint is easy to work with
I don't really do any big orders at the min so I want to be able to print and press small quantities quickly.Is there a company in the UK that sells transfers? Then all you need to do is heat press. Much easier and faster than printing, contour cutting, weeding etc...
Looks like it's not for latex, only eco solvent.Thanks, I'll have a look at that, is it OK with latex?
