huge glass install ( dry ? )
Discussion in 'General Signmaking Topics' started by laforestsigns, Dec 21, 2009.
  1. laforestsigns
    laforestsigns Member
    29
    Since I got so much helpful advise on my last post here's one more ! I have an interior glass job to do in Charlotte NC , it's about 100 windows forming a picture from the outside . I'm using 2 layers . first is a transparant print on clear , and second is a transparent white panel to darken the clear print . ( customers spec not my choice ) Anyway i'd love to get more info on the dry application method . as this would save me a HUGE amount of time . prints are 46 " x 140 " each . we did one in time square and it came out great but took two days with a wet install . no bubbles , but tons of time ...... Any advise ? or anyone experianced in NC looking to be a sub ?
  2. Just Another Sign Guy
    Just Another Sign Guy Very Active Member
    3,057
    like i said. use the hinge method.
    send out two ppl to install one to hold the other side of the graphic one to squeegee.
    if the guy holding is not skilled at holding the graphic taunt apply the edge to a straight edge, broom handle so that equal pressure is applied to the entire graphic making it smooooth going for the installer.
    wam bam thank you mam
  3. Des6139
    Des6139 Member
    170
    why not laminate the first print layer with second white layer at factory. Why cant'nt it be wet applied
  4. kev3232
    kev3232 Member
    376
    i concur with des. lam the white part on the print and wet apply them sucka's!
