i broke the drain line to the waste tank
lisa marie
i was trying to pull some ink thru the waste line and it wiggle up in the cap, and i pulled it with a needle nose plier, and it broke off. now i cant pull ink thru... any advice? i've searched for a part and i'm getting nowhere
damonCA21
Which part of the waste line? There are lines from each cap top that go into the pump, then a single line that comes out of the pump into the bottle.
If it is the one from the cap top you have probably just pulled the line loose from the bottom of the cap top
