I got shticked with a Publisher file....
Signsforwhile
What do I do with this thing? Someone "designed" business cards and I need to make it acceptable for 4over....anyone know how I can use this? Really not into resetting everything...
:help::thumb:
Marie
In Publisher: Under FILE menu / select Publish as pdf / At the bottom of the window, click the Change button and select whatever option fits your job
After that step, open the file in Illustrator to verify that it is in CMKY and is the correct size.
Good Luck - M
