I have a few questions.HP always has some really good ones with the spare parts. Blunt tip needles that won't puncture anything. Even a T-valve on a tube that you can change the direction of flow so you can basically pump ink between two cartridges.
Question when you say get some chips to put on the cartridge, what do you mean?I'd suggest just getting some chips to put on the cartridge to finish them up. Cartridges are filled with ink and then all the air is sucked out. If you introduce air into the cartridge, it can cause pressure issue which usually ends up in ink just falling out of the head.
I have installed shims under one end of the cartridge to raise the angle slightly, but there is still a good deal of ink in each cartridge, and I have many of them.
It seems so wasteful just to keep getting rid of cartridges with ink left in them.
Jim
Thanks for explaining that to me, as I did not know how that worked.The way the system works is each cartridge has a chip that identifies the color but also keeps track of the ink level by subtracting the estimated ink usage as the machine is used. Once that hits 0, the chip reads as empty even if it estimated incorrectly and there is still ink present. Usually if a chip reads 0 before it's actually empty, it's a sign of a bad maintenance station or the next issue below.
There is another sensor in the cartridge area that detects if the cartridge is physically empty as well. It's a plastic flag that pops out of the cartridge when it's empty. When that trips, the cartridge should be as empty as it can be but sometimes it gets hit early and then sets the chip to 0 automatically even if ink is still present. Once a cartridge hits 0, the chip is done for good and will always read 0.
So in your case you might be in one of those situations and if that's the case, you can just get a new chip that is set to 100%, pop it on the cartridge and finish it off. Once the flag trips the sensor, it will set the chip to 0 again.
There's always a little ink left in the cartridge but it should be negligible. If you can feel ink still moving around in there on a regular basis, it could mean your maintenance station isn't pulling enough ink during cleanings. Essentially, that's the ink it would have pulled if it was working properly.
Each cartridge I have has a good deal of ink left inside it. I will keep working on this problem because It's crazy to just keep wasting ink!
Jim
The chip doesn't control ink flow, it stores the percentage left (printer tells it to the chip and can count down only), expiry date, color, and if cartridge is genuine, so if you have 9% left and put it on another cartridge it'll still show 9%.On a Roland Ink Cartridge, there is a small circuit board on the front of every cartridge, is that what control the ink flow and everything else?
There is only one small screw holding it in place.
If I replace this with the circuit board off a new cartridge, would it work? Kind of like using a chip resetter.
I have not tried it yet and was just wondering if anyone else has>
Jim
Yes it's time-consuming and messy if not done carefully, when i had more time than money (orders) I used to that, now that my time is more precious I don't mind throwing out 50ml of ink which is 10% waste on a 440ml cartridge ($8-$9)
don't use vinyl as ink will dissolve it over time ->> when trying to fix a puncture on an ink bag
