I need help! Pulling my hair out!
ExposeJustin
Anyone have any success with print plots on Graphtec plotters using reflective?
Im having trouble with X and Y errors when trying to cut this reflective that we printed on. Its a nightmare and I cant get anyone at Graphtec to help. I get errors about "Sense Level Not Enough" so when I adjust that, I get errors about the "-Y or +Y area not being the correct length".
Its driving me insane.
Someone help me! :frustrated: :help
Tim Aucoin
I've heard that plotting/cutting black "dots" (obviously the proper size) and applying them to your sensor points works when cutting reflective on any cutter. I haven't tried it, as I don't do too much reflective, but might be worth attempting.
For a moment when I first read your thread topic, I thought you wanted help pulling your hair out... that I can help with!! :ROFLMAO:
ExposeJustin
I was able to wade my way through the job - I actually used transfer tape, "re-drew" the cutter marks with a sharpie, and prayed real hard and it worked.
Not sure which part fixed the problem, but when cutting reflective now, I do all three.
:rock-n-roll:
TDFcustomSL
I have put scotch tape over the marks and it works SOMETIMES. one trick is to use 1 piece of scotch tape at an angle across the entire mark (if using 1 inch marks) otherwise it tends to "read" the edge of the tape instead of the actual mark. For when scotch tape doesn't work, I put a square of Transfer Tape over the mark and re draw it with a felt tip pen. Then of course there have also been times where I needed to do nothing and it read the marks just fine. USING THE SAME MATERIAL!
omgsideburns
Besides the methods listed here I've done these two with varying degrees of success.
- I'll let it print the first pass of the marks, pause the print and stick a piece of white vinyl or tape over the spots it's printing them, and then let it continue. Just don't forget to do the same for the end marks.
- Scuffing the vinyl so it doesn't reflect as much. I just use a little wire brush, some fine grit, or whatever you've got laying around.
