i need help with pc60 please
stickergurl
I can't figure out what the icc profiles are so flexipro 7 will not print. It cuts but it cuts a line through the graphic when it is done but not always. I need help. Thank You
The Big Squeegee
Long Time Member
Welcome from OK
A little about yourself and a search through the archives will go a long way in these parts. There is also a forum for the edge machines you might try.
Sign Works
You've got to go through the Production Manager set-up and Output Device Configuration, go to file menu > rip & print, this will take you through the set-up and should prompt you for disk #2 which will install the necessary profiles for the selected output device (PC-60 in your case). You can refer to page 158 of your Flexi Pro User Manual, it's all right there in black & white for ya, at least this is the case with Flexi Sign Pro 6.5 which I run my PC-600 from very efficently. Good luck & welcome.
