Greetings,
I know several people here are interested in this so here is the info I have so far regarding the printer I got and where I'm at with it at the moment:
The model I got is the ultra 9000 1602s (1.6meter ot also maximum with that media would fit in is 61.5" ) dual dx5 printhead solvent based.
Here are some detailed pictures of the printer itself inside my garage and also some close ups of the parts:
http://www.sendspace.com/pro/o91j35
My impressions of it is that for the money I paid $6500 + $45 money transfer fee + $713 shipping seems to be very good. Nice design and doesn't fell too raw......
It comes with 2 CDs one is the printer software the other is the RIP (maintop ) software...all in all once installed looks like there are 3 diff programs that you can run at the same time to use with this printer.
Program 1 is "Ultra 9000" which is the main printer software, in which when you start can select if you want to use the machine with the left printhead only, both printheads or the right one. Once in the software you can control pretty much all the options on the prints from there....any adjustments are also done in this software...etc...
Program 2 is the MainTop RIP which you can import JPG...TIFF etc files and then you export then as a PRN file which you can then import into the Ultra 9000 software and print.......at least that's what I've done now when testing
Program 3 is called Print Manager and it looks like the Mimaki Rasterlink software where you see all the jobs....and their statuses....etc...but I haven't figure out how to print from here....or if I should print from this software at all....will see
I still have alot of homework on to how to figure out all of the above as the manual doesn't say much about them.
So I got everything installed.....put some cleaning solution into all the ink cartiges .... pumped cleaning fluid through all the ink lines into the heads...etc..... then I added the ink.... did the same ... ink pump .. .then ink flush ...
Everything seems to be working fine excepty only issues I'm having now is on head # 2 (right) black and cyan nozzles do not fire up when I do an ink flush.... I can see all the vaports from CMYK firing up pretty good on head #1 ... and on head #2 I only see Yellow and Magenta..... I did a cleaning and ink pump and unk flush... and nothing.... still the same thing....so I'm not sure but i have to research more on this as my 1 litter waste tank got full from all my tryings......
and yes I did check the seal on the capping with the head and it looks like it's sealing fine....so I was told it might be vapor lock....
So before I can do the head allignment and adjustment (software and hardware) I have to figure out the problem above
I will let you know more very soon....
Regards,
Chris
Regards,
Chris
