I purchased a new Mutoh Xpertjet 1641SR two months ago to replace our 14 year old Mutoh Valuejet 1604.
This so far has turned into the biggest issue ever even though basically it is still based on the original Valuejet.
Their are very little print profiles for this machine from such suppliers as 3M, Arlon, Avery, Etc..
Of what profiles I have the media is either applying to much ink or is producing a sub standard print.
The ink tank/bags do not show correctly how much ink is still available and will completley run out even though it is showing 30% full.
Ink supply for this machine in the UK is very limited and my machine has been sitting for nearly a week switched on (as you cannot put it into standby when tanks are empty) due to supply issues. Which as usual here is blamed on Covid or lack of lorry drivers!
I have blurry prints and although better colour gamut and good matching the prints are still not as high quality as the 1604.
My 1604 is in storage across in my unit (turned on) and I am seriously thinking about sending this back and reinstating it.
This is a buyer beware post as I do not want other business owners to fall into this trap.
Mutoh are not helping and the reseller we have bought of (Mutohs only dealer in the UK) are under educated in the machine and Onyx RIP it was supplied with.
SC
We recently purchased this printer as well and although we have been able to get some really quality prints using this machine, we are experiencing some issues and are also receiving little to no help from our vendor or Mutoh.
One thing we discovered is that if use the Avery 1105 profile on a standard white vinyl (not Avery media) the quality is very decent. Same with the Arlon profiles provided through Sai Cloud.
Keep in mind that the printers heat settings are only adjusted through the driver option I’m Flexi, regardless of changing the settings in the print manager. Just a word of advice of changing any setting because it is extremely confusing.
I want to ask if you happen to notice a different issue that we are having. We have noticed that the core rollers or flange rollers are coming out of our media when loaded onto our machine… if you look at the back of your machine you will notice a warning label saying good and not good. This label depicts the flange rollers metal torque piece scraping against the rollers.
We have tried everything and have found that the media coming off the rollers is causing head strikes… our vendor and Mutoh say that have not seen this problem but we have tested various media types and the flange rollers can easily spin inside the media. All media we use has this issue where the rollers come out of the core with every revolution of the media.
Would love to hear if you are still using machine and have this issue as well.
