I would appreciate
laserman70
If someone could give me some help..
Using Flexi 8.6v2, I opended the eps, contour cut it, imported the image over top of the contour cut. When i go to cut it it tells me nothing to cut lol oh boy. below is a pic of what i have.
G
gps-hi
Guest
Off topic, but can I nit pick? I'd remove the line across the top of the skulls so they don't look so much like medical pieces.
DRPSignsNGrafix
More info may help. WHat printer cutter are you using? and to get the cut path to top, just select it then click arrange,order,to top
DRPSignsNGrafix
1 open the file u want to print. (the green skull thing)
2 Open the EPS cut file, place on top of Green skull thing
3 click on cut line, then click arrange, contour cut, make contour cut
4 click rip/print button
amgraph
Have you actually created a cut line under either effects> contour cut or converted a line under arrange contour cut make? You can also do >select by attributes and look under stroke. There should be a stroke named Contour Cut.
laserman70
Ok, when i open the eps, it opens in a sepreate document. How do i get it into the green document?
laserman70
Where did u buy this stuff from? No training?
No u should see the image as well as the registration marks
Bought this from, a person who went out of business. I just had a little cutter for one color vinyl. Had to transfer the license and upgrade and they sent a disk with no book. Sorry.
