Icc profile with higher ink density to be used on a lower pass
Kemraj
Good day i have a question about the icc profiles. I have a hp latex 365
So for instance we know 6 pass don't use higher than 100 Ink density.
But if i use my 10pass 120 ink density or higher icc profile and use it in the 6 pass profile Will i achieve higher Gamuts? Will this work.
jimmmi
How are you going to do this? The reason 6 pass goes maximum 100% ink is that more ink won't cure in 6 passes. Media stays too little time in curing zone.
Kemraj
The you can select anther icc profile on the flexi software and if you go to edit the profiles in the printer you can select another icc profile with a higher pass.
dypinc
Most likely lower gamut as it was based on 120 ink density and very well could have dialed back gamut based on the density. Make a new profile for your 6pass mode.
