IDEA: Reverse Print Cut with White Laminate
M D Gourley
Hello everyone,
Not sure if this subject has been covered, but I had to come up with a way to Digital Print a reverse graphic with White Laminate and then machine Contour Cut for a Decal applied to the inside of a Glass Window.
Results below that worked out great on my Roland VP 540....hope this is of help to anyone.
If there is a better way please reply...thanks
  • Agree
Reactions: 1 user
equippaint
You can offset your crop marks a little and then cut the white short of them rather than cutting out the marks. If you're making sheets and not a roll of course.
  • Agree
Reactions: 1 user
OADesign
M D Gourley glad you figured this one out. FYI this has been around for a while. Roland actually release a "book" with this and a ton of other tips back in 04' (I think).
Google it. Search "Taking-the-Mystery-out-of-Print-Cut". It will probably take you right to a PDF of the book. There is some good stuff in there.
  • Agree
Reactions: 1 user
M D Gourley
lol...eventually I will get there...thanks for the reply
