ignore overprint?
gabagoo
In Flexi rip there is this box "Ignore overprint" that is always checked off. I have no idea what it means. What happens if I uncheck it?
gabagoo
so you mean that the layers would print together with nothing over anything else? I guess I should try and see what happens
SebastienL
If you ignore overprint, then you should be ok.
If a file as overprint setting in them, which is usually for press printing, and you don't ignore them, you will get screwed up colors.
Let's say that you are printing black text over a picture. In press printing with no overprint, the rip will put white "holes" in the picture for the black to go in. With overprint, the black will go over the colors, the rip won't leave white for the black.
Does this make sense?
CS-SignSupply
Check to ignore any overprinting that was set up in the design stage. This can be useful if you want to save the time and output media needed to do overprinting.
If you check Ignore Overprint, your output will automatically be changed so that it will not use features that depend on overprinting. For example, output that had been set up to use color trapping will now output untrapped.
