Illustrator mystery...
Discussion in 'Adobe' started by iSign, Apr 2, 2007.
  1. iSign
    iSign Major Contributor
    13,027
    31
    48
    Nov 29, 2003
    Kahului, Maui
    I've been using this software for about 15 years... but I stick with what I know & don't really venture too far into learning new stuff... then once in a while some really basic little thing has me stumped.
    This past week, I've been encountering this recurring issue that really inconveniences me, but i haven't noticed a pattern of when it happens. I don't really remember it happening before, but now it seems to have haunted me 4 or 5 times, then it's gone awhile... then it's back.
    It seems as though it would be a preference setting that I need to change, or a client file that is operating under their prefs, instead of mine... but usually copying it to a new page fixes that kind of issue, but this idea doesn't work in the case of this weeks mystery.
    When I select something, I often depend on those handles in the corners & the center for use in resizing, & also for locating guide lines at my centers.
    Why are those handles not showing up on several occassions & several different files this past week?????
    I wouldn't be surprised if this is something so easy I'll be ashamed for not figuring it out... but that shame will be less inconvenient then dealing with this mystery for another week :help:
  2. iSign
    13,027
    31
    48
    Nov 29, 2003
    Kahului, Maui
    oh yeah... "show bounding box"
    I must not have had enough sleep, coffee... or time off this week :(
  3. Rick
    Rick Certified Enneadecagon Designer
    6,955
    389
    83
    Apr 17, 2003
    Valle Vista
    Me and the bounding box have never gotten along....I always keep mine off.
  4. Geary
    Geary Very Active Member
    Oh, I know...it's "show bounding box". :tongue:
    Just kidding Doug. You know though...I also like Illustrator a lot and I have used it since it's inception right up to 7 . That's it. That's all I use in Ai. But, I know I should upgrade to CS...I just don't. No printer here...and I use Canvas and LXi. I suppose that's why. I'm just on a slow burn these days I guess. :wink:
    ~Gear
    ps.....I do know why you like the bounding box. Otherwise the "scaling" technique suffers on Ai....imo.
  5. iSign
    13,027
    31
    48
    Nov 29, 2003
    Kahului, Maui
    I always keep mine on... but I "hide" the artboard & page tiling quite often... and sometimes in a rush, I guess I hit "hide bounding box" by mistake, so I go back & hide what I need hidden... but forget to unhide the bounding box.
    Then I get a week like this last one where I'm so scattered, I didn't slow down long enough to figure that out all week, until now that shame was at stake :rolleyes:
  6. Rick
    6,955
    389
    83
    Apr 17, 2003
    Valle Vista
    With the bounding box, I have noticed a couple of designers at my last job would get a little lazy and accidently squeeze and squish type at the tiniest amounts. I would call them on it when I was doing the production/construction doc files. After seeing them work, I noticed they usually forget to hit the shift button or release it too soon to keep the scale uniform or more often try to move the file and inadvertently scale it down....drove me loco!
  7. Geary
    Well, I just went back and checked on my version 7. I don't even HAVE "bounding box" options. LOL That was on 10 back at the shop I worked at last up north. ha!
  8. sullosau
    sullosau Active Member
    537
    I have illi but I havent really tried to learn it, I have Corel and well since I did learn that one, even reading the manual on occassion!
    But when ever I look at the desktop and see the illy icon just sitting there laughing at me I say to myself, I will learn you one day.......
    Until I get the time for that day illy will remain a mystery to me, but I get the results I need so it can just sit there and keep on laughing...
    And yeah, havent had enough coffee either..
  9. thewood
    thewood Very Active Member
    1,781
    Dec 28, 2005
    Tennessee
    It's the worst, and I've done it in Illustrator and Photoshop. I think Flexi is
    much more "scale-friendly" both manually (since proportionate scaling is the default) and using Design Central.
  10. The Dotted Line
    The Dotted Line The Dotted Line
    Island,
    I think it is the Bounding Box or in the View menu called "Hide Edges." Sometimes I accidentally hit Command H (Control H on PC) when I am trying to hit Command G. That toggles the "Hide Edges" off and on. So if you've done it once, do it again to get it back.
    Good luck!
    James
  11. signguy95
    signguy95 Active Member
    580
    I'm just now learning Illustrator and trying to get in the habit of using the shift when scaling...But I use flexi at work and I catch myself hitting the shift key by accident.
    In flexi, holding shift when scaling will do right the opposite!
    Jay
  12. animenick65
    animenick65 Very Active Member
    1,320
    May 18, 2005
    Boston, MA
    Illustrator annoys the hell out of me. Its so unintuitive. Scaling should always be proportionate with the option of holding the shift key to scale unproportionally.
  13. thewood
    1,781
    Dec 28, 2005
    Tennessee
    I agree!!!!!!!!!!
  14. iSign
    13,027
    31
    48
    Nov 29, 2003
    Kahului, Maui
    actually Flexi keeps running me in circles, because after 10 years of Illy... shift keeps movements on axis... and it keeps things proportionate... makes sense to my intuition... but of course, after 10 years... I should hope so. (I only have 2 years with Flexi in my shop & my employees responsibilities are where that program comes into play the most)
  15. Ian Stewart-Koster
    Ian Stewart-Koster Active Member
    845
    15
    18
    Sep 27, 2003
    Qld, Australia
    But flexi has a lot of the same shortcut functions as Photoshop, with a few corel ones thrown in for good measure!
