Illustrator not opening CuttingMaster "Registration Marks..."
GP
Not sure if CS6 had some sort of update - but for some reason, CuttingMaster will not open the registration marks window.
CuttingMaster 2 is still an option in the File menu, and it's black - but "Registration Marks..." won't open to the next window.
Anyone have this problem and find a solution?
Dennis422
You might want to remove everything from your Plugin folder and reinstall CM2.
Also, try if CM3 will work with your cutter. It is MUCH better software than the CM2.
Dennis422
Yes. I had CM2 with my ce5000-60 but when I bought new FC8600-130 it came with CM3.
I know that new CE6000 are shipped with CM3 but I do not know if it will work with older cutters.
http://www.graphtecamerica.com/support/
It looks like you can get it for older ones too. I do not know what you have
