GAC05
Quit buggin' me
Illustrator does have a dedicated function built exactly for this. The Asset Export panel allows you to drag and drop any number of objects to queue them up for exporting. Then you choose your format and Export them all at once.
If you just want to export one object, you would instead go to File > Export Selection. This will open basically the same set of options as the Asset Export panel, but for the one object you've selected.
The only catch is you have to export to PDF, not AI. That shouldn't be an issue since any application that can import AI files should be able to import PDF files. Most apps that import AI files are actually reading an embedded PDF file that's saved inside AI files by default.
EDIT: if any of this isn't available in CS4, it'll be there when you upgrade to CC, which I'm assuming you would do if you were going to use Illustrator on a regular basis for opening client files.
Didn't know about this one.
Just tried it out. Looks interesting but seems it expands the art board out to the limits of any masked objects included.
Seems about the same amount of work as saving out the art boards but will need and action or something to fix the art board size.
Thanks for posting this up - learn something new here (almost) every day.
wayne k
guam usa
