im getting my butt kicked!
dmeehan31
hello!
i am using flexisign 8.1 and have an issue today... not sure what i am doing wrong. i have not had this issue before.
not sure if something in the production manager got switched or what.
my issue is i need a peice of vinyl to cut 18 inches long and 22 inches wide with the reverse weed to take the letters out.
i have my rectangle the size i need and the letters placed where i need them in the program.
when i send to cut it only cuts 17 x 20 i am trying not to waste vinyl but i am not sure why its not cutting to the size i have it designed in my program.
please give a hand here! thanks!! :U Rock:
Graphics2u
Check the size when the cut/plot window opens. Sounds like the job scale got changed by accident to something other than 100%.
dlndesign
Check and make sure the plotter is set up to accept the size you want. You may need to change orientation or the scale. The little plotter with the ? mark in production manager should refresh and let you know that you are working with the correct size. Hope that helps
