Im in trouble please help me!
Discussion in 'Graphtec' started by james potts, May 5, 2006.
  1. james potts
    james potts New Member
    9
    i have been using my graphtec fc2100-60 for about 3 years, has never let me down and is a fantastic bit of equipment. however, i came to use it a couple of days back(the same as i always do) and it stopped working. it switches on fine and test cuts are perfect. i use signlab 5.0 as my main design package and when i go into plotter id it says that the plotter is not responding. yet when i send anything to cut, it cuts a code instead of what i have asked. the code is U2439613116. i have changed the lead just incase it was struggling to translate the images or the connection was faulty but that hasnt made a difference. im out of ideas, i think ive tried everything from loading signlab up again, putting the drivers on again. i have even tried it on a different computer with signlab on it but it still says the plotter is not responding and sending out the code when cutting.
    if anyone can help you would be a lifesaver. i dont have an instruction manual as i bought it off of my old boss and he didnt have one so i cant even look through that.
    please help me as i have jobs waiting, and im getting in a bit of a panic.
    all the best, james
  2. Bigdawg
    Bigdawg Just Me
    7,462
    133
    63
    Jun 8, 2005
    Sunny Florida
    James - which Bristol are you in....
    Don't know anything about the graphtec, but if it's my Bristol, we may be able to help you out with the jobs you need to get out.
  3. Bill Modzel
    Bill Modzel Active Member
    Did you accidently change the command line?
    Menu>Interface>Command> HPGL/GPGL
    I switch mine back an forth depending which workstation I'm using.
    My old Mac G3 uses Signpost and HPGL code with a serial connection.
    MY G4 used Graphtec's Cutting Master and GPGL with the USB connection.
  4. james potts
    9
    to be honest i didnt touch anything. i just turned it on. i will have a look though, im willing to try anything. that sounds quite promising.
    thank you bill.
    to bigdawgdesigns. its bristol near the m5. by bath etc
    that would be great if you could help.
    cheers
  5. Chad.
    Chad. Active Member
    659
    1
    Call graphtec ... they attempted to walk me through getting my FC5100 talkin to gerber omega ... That was a trip.
  6. james potts
    9
    cheers mate. i have tried but got annswerphone. left a message. will try again on monday.
    thanks inletmedia
  7. SSS_Tech
    SSS_Tech New Member
    16
    It does sound like an HP-GL/GP-GL issue. That particular model is a bit before my time, and I have had no exposure to the model, but if it has a control panel try and access the COMMAND options and verify that the cutter is in HP-GL mode. You might even try to perform a NOV RAM (unit reset) to see if that may correct the issue. NOV RAM: Power down, hold in the up arrow key and turn power back on while holding down the up arrow key. Follow screen prompts and reverify that the cutter is in HP-GL mode.
  8. Derf
    Derf Very Active Member
    I had this problem with my FC2100-60 I turned out to be the Cable and if I'm not mistaking Graphtec has a proprietary cable.
  9. james potts
    9
    cheers derf & sss tech. im not in the office at the moment. but that is excellent help. i will try them first thing tomorrow.
    much appreciated.
    :thankyou:
    to all that have e mailed so far. this is my first time on signs101 and i can honestly say that the response i have had is brilliant. you have all given me fresh hope, i had pretty much ran out of ideas. but because of your response i have fresh hope and cant wait to get into the office tomorrow.
    this forum is spot on with nice genuine people willing to help. i will definately tell others in the sign field about it.
    cheers
  10. robpruitt
    robpruitt Member
    80
    This forum rocks with the great tech support. Great stuff.
  11. Creations
    Creations New Member
    19
    if you switch the pins around any cable will work.we use a male to female serial port and that was enough to fool it....
    P.S. this forum is the bee's knees!!
  12. OneUpTenn
    OneUpTenn Active Member
    870
    1
    18
    Sep 23, 2007
    You guys are just freaking great!!!! This forum is awesome...so many people willing to help out other people.
  13. Idea Design
    Idea Design Very Active Member
    1,019
    2
    38
    Jul 12, 2005
    I wonder if this 2 year old problem got worked out.
  14. cOrKinSA
    cOrKinSA Very Active Member
    2,242
    2
    Dammit Creations you Noob!
    What are you gonna do next? Pull up a post from Jesus's Diary!
  15. animenick65
    animenick65 Very Active Member
    1,320
    May 18, 2005
    Boston, MA
    Wow, didn't even notice the date. Damn, hope that problem got worked out!
  16. bluttr
    bluttr Member
    82
    LOL This post was from before YOU were even a member here!
    :cool:
  17. cOrKinSA
    2,242
    2
    When you see the Avatars you figure something good is going to be written and never take account on the timeframe, but then as I continued reading I said to myself "Hmmm must be new members". Boy was I wrong.
  18. iSign
    iSign Major Contributor
    13,027
    31
    48
    Nov 29, 2003
    Kahului, Maui
    ah yes... the victim of the first banning that I recall...
  19. cOrKinSA
    2,242
    2
    Oh, well then let's gather around the fire and here a story.
  20. iSign
    13,027
    31
    48
    Nov 29, 2003
    Kahului, Maui
    ask Flame...
