Import PDF to Flexi and font changes
JMo56
I am stumped...I have PDF files that I import into Flexi 10 and the fonts sometimes change to Courier. I have no idea why this does that. I have the fonts that are on the PDF, its most common with Times. Any ideas or suggestions on how to make it just import the way it is? Thank you in advance.
TNsignchick
There are several different types of times, formatting-wise. There's open type, true type, flexi-supported. It may be the same font, but a slightly different format or name. Best thing is to have the pdf completely converted to outlines before trying to import, or if you have acrobat professional, export it as an eps with fonts converted to avoid this corruption
jayhawksigns
If you are just needing to print the pdf, just open it in PM and output it. A file that Flexi will butcher will open just fine in PM most often.
Only helps you though if you don't need to do any editting to it.
JMo56
thank you I will try that!
Fred Weiss
If, however, you need to keep the type editable, then you need to possess the same fonts in the same format that were used by the creator of the file and have them installed when you import the file. Just having the "same" font from a different foundry isn't going to be recognized as the same as used in the file.
RiXaX
I use an older version of Flexi, but per chance my comments might be valid.
I think when I make a PDF the fonts are changes to vectors. When I open a PDF I usually need to unmask and the text are not in a font format. Is this different in newer versions?
