Importing .PLT files into Flexi?????
Discussion in 'Gerber Omega, Graphix Advantage & MacImprint' started by Shovelhead, Mar 21, 2005.
  1. Shovelhead
    Shovelhead Major Contributor
    10,882
    16
    I just got the latest Flexi....there are (3) HPGL (.PLT) options to import into Flexi....none are working....
    :help:
    :Coffee:
  2. Sign to Go
    Sign to Go Member
    234
    You might want to try to drag the file right on to the Flexi Drawing Area. Jim:wink:
  3. Fred Weiss
    Fred Weiss Merchant Member
    20,921
    545
    113
    Sep 11, 2003
    Olympia, WA
    HPGL PLT is different from Gerber PLT,
  4. SteadyBenny
    SteadyBenny Member
    155
    I've noticed plt files from Corel have excessive nodes, almost like cutting a bitmap...
    I'd convert to AI 88 or 1.1 which Flexi has no issues with at all.
  5. Fred Weiss
    20,921
    545
    113
    Sep 11, 2003
    Olympia, WA
    You're confusing HPGL and Gerber PLT. HPGL is linear data, hence lots of nodes. Gerber PLT is bezier curves and is completely different. Current versions of Flexi do not import Gerber PLT.
  6. Dennis Raap
    Dennis Raap Active Member
    586
    Oct 5, 2003
    USA
    The next version 7.6 does support direct importing of Gerber File formats.
  7. Matthew Scher
    Matthew Scher Member
    109
    2
    18
    Dec 2, 2003
    NJ
    PLT files are not problem in Flexi 7.6
    We announced Flexi 7.6 yesterday and it will be coming out this week. It includes import filters for Gerber GA and Omega PLT files.
  8. Fred Weiss
    20,921
    545
    113
    Sep 11, 2003
    Olympia, WA
    Thanks for the clarification Matthew.
    So, as a beta tester, I'm not sworn to secrecy anymore?
  9. Dennis Raap
    586
    Oct 5, 2003
    USA
    Thats why I mentioned it I got an email stating that it was released. :wink:
  10. Matthew Scher
    109
    2
    18
    Dec 2, 2003
    NJ
    Flexi 7.6 has been announced
    Hi Fred,
    Yes, Flexi 7.6 was announced this week and you should be able to find details of what is new on our web site. Feel free to discuss the new features that you used as a beta site.
  11. Bob Gilliland
    Bob Gilliland Member
    112
    Does Flexisign 7.6 support the new Gerber 2.1 plt file format or only versions prior to that (Omega 2.0 and lower; GA 6.2 and lower)?
  12. Dennis Raap
    586
    Oct 5, 2003
    USA
    Not sure on that one Bob hopefully Matthew will have an answer.
  13. BBworks
    BBworks Member
    26
    OMEGA to FLEXI THIS IS POSSIBLE!!
    I have Flexi and 2 versions of gerber omega. I need nto print and cut back and forth all the time. Flexi wilkl open omega .plts saved as version 1.56 but not the 2.0 versions. Flexi will alow you to open as cuts or print and cuts.,
  14. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    19
    holy thread resurrection, batman!
  15. sar bossier
    sar bossier Very Active Member
    1,189
    1
    :ROFLMAO::ROFLMAO: :goodpost: :ROFLMAO::ROFLMAO:
