Info needed on routing HDU
Discussion in 'CNC Routing & Laser Cutting' started by jayhawksigns, Aug 3, 2005.
  1. jayhawksigns
    jayhawksigns Very Active Member
    1,209
    34
    48
    Jan 8, 2005
    Kansas
    It seems that when we start doing something new, that suddenly everyone wants it.
    I am going to starting routering out some test pieces in HDU this weekend and wondered if anyone who is doing HDU now could tell me what range for feed rate and spindle speed you operate at? And suggestions for types of bits to use too. I have single flute upcuts and ballnoses that I will be playing with this weekend.
    We will be doing some routered HDU signs for the local school, nothing big, 30"x10". And today we got in a job to do 2 - 46"x42" signs for a local deli, again in HDU. Be some interesting projects, and hopefully once they are up, we can push some more dimensional signage around here.
  2. SignRover
    SignRover Member
    134
    Dusty stuff. Get ready for a scratchy throat.
    We cut 15 lb Signfoam and Precision Board HDU's at 1.5 IPS with Onsrud spiral upcut 1/4" bits. Spindle speed at 22,000 rpms.
  3. James Chrimes
    James Chrimes Very Active Member
    1,033
    5
    38
    Jul 4, 2005
    NEWPORT NH
    Everyone Will Want It. Just Make Sure That You Charge Appropriatly For It.
  4. jayhawksigns
    1,209
    34
    48
    Jan 8, 2005
    Kansas
    Thanks for the info on the settings to start with when I do some cuts this weekend.
    Also, what on average do you charge for dimensional signage?? Below is what one job will kind of look like, layout isn't finished yet, and I know I forgot a number in the time, but I took home a dxf of the job to build it in 3D to see what it would look like and I couldn't edit anything.
    [​IMG]
  5. Dennis Raap
    Dennis Raap Active Member
    586
    Oct 5, 2003
    USA
    HDU is easy to cut I run 250 in/min at 19,000 rpms.
    I use .5" up cut bits for large areas and finish up with smaller bits in the tight areas.
    If your software has the capability you can use bits that have different angles to do V Groove or Prismatic effects for letters and other objects. :Cool 2:
  6. jayhawksigns
    1,209
    34
    48
    Jan 8, 2005
    Kansas
    The software can do v grooves, just haven't gotten around to messing with it yet. And with the size of the sign, gettinga .5" upcut probably would be a good idea, hadn't though about that.
  7. Dennis Raap
    586
    Oct 5, 2003
    USA
    What software are you running?
  8. jayhawksigns
    1,209
    34
    48
    Jan 8, 2005
    Kansas
    ArtCAM
  9. Dennis Raap
    586
    Oct 5, 2003
    USA
    I have never used Artcam but I Know that you have a good one.
  10. jayhawksigns
    1,209
    34
    48
    Jan 8, 2005
    Kansas
    I have been real happy with ArtCAM, I have seen some other software for designing for routers and they didn't seem near as easy to use.
  11. dccas
    dccas Member
    234
    1
    I route my HDU with an 1 ½ HP Hitachi plunge router and a 1 hp
    hand held Porter Cable
