Ink cartrige drained????
HELP ME
If so I went to replace the cartidge I needed to and now my BLACK CYAN AND LIGHTMAGENTA COMPLETLY DRAINED> WHY I did pull them out last week to see how much I had in them before ordering my yellow. Obviously the waste tank is full. Can :omg2:anyone help me.
CheapVehicleWrap
Unfortunately this won't be the last time this happens. Things NOT to do. Do not remove cartridges..check status on menu otherwise these numbers get out of whack and you'll have cartridges with ink registering as 0% full. I would also NEVER do a 'little charge' again. They sure named that one wrong. It started for me when I first ran the cleaning cartridges at set-up and the printer ate 4 ENTIRE 220's. right in the waste tank.
Graphics2u
I don't think taking your cartridges out anything to do with it. And it sounds like you have a Falcon series printerbecause you're using lt. magenta. So what could have happened is the pads in the capping station are swelled up touching the bottom of the heads cauing the ink to syphon into the wasts bottle.
If you do have a Falcon printer they don't use chips on the cartridges so the only way to tell how much ink is left is to pull them out. So I'm sure that's not what caused your problem.
Check those pads and se if they look like they are puffed up.
