Ink Draining back on Cyan Lines
heyskull
My old Mutoh 1604 has a problem.
The Cyan ink lines drain back and have air in them when I caome in on a morning.
Am I correct in assuming this is a damper problem and need replaced with the O rings?
Or is this the internals of the head creating the problem?
I am hoping to buy a new one in the New Year so just hoping to nurse this one till February!
I wanted a 1604X to replace it with but Mutoh have discontinued it.
SC
Umca
Normally if the damper is detached from printhead and all pipe connections and damper in good condition ink will not go back.
So, it is pipe connections (O-ring) or damper proplem.
heyskull
Brilliant I have spares so can replace O rings.
The last technician I had to it reckoned only ever replace the dampers if they were failing.
I hate touching this part of the print head as damaging it can render me completley out of action.
SC
Umca
Actually, you have to cut edge of plastic pipe. Under old O-ring. And locate new ring on undamaged place. Because the ring made a jam of pipe and air can leak easily on that place.
  • Agree
Reactions: 1 user
