Mutoh Falcon II Outdoor 64"
I'm at my wits end with this printer.
Ok, Please see the attached pictures.
What I have appears to be an ink drop out on the Magenta head. Let me start by saying I've done coffee filter soaks, I've replaced dampers, caps, pumps.
Here are the details. I noticed this drop out especially because I was printing a job that used most of the width of the printer and in some places has heavy ink usage. The drop out seems to happen after about 3-6 inches into the job. To duplicate the symptoms and try to troubleshoot, I printed the same job, but inserted four color bars between the two images I was printing. I know that Onyx does not send the the black bar as 100% black, even though that's what I made it in the file. I know this because I can see some slight banding in the black and possibly the cyan. But most noticeably, I see the banding on the magenta.
Questions set 1:
Is it fair to conclude that this in fact an ink drop out?
If so, is this occurring on the magenta head?
Here's what I've done:
I have replaced the black head.
I have replaced the pumps that serve the Black/Cyan and Magenta/Yellow
I have replaced dampers on the black and magenta heads, although I'm not confident that I've done the damper replacement properly.
The dampers I installed were high-flow dampers, in other words, they had wider screens rather than the little round screen inside.
I have also replaced the caps at the capping station with new ones, then a different set of new ones because I thought maybe the first caps I bought were cheaply made and not of good quality.
I then went back to older caps because none of the print heads performed well on a nozzle check after the printer sat off and unused over a three-day weekend. In fact, they were terrible and unusable.
I have taken the black and magenta dampers off again and sucked ink back into them, but again, I'm not sure I've done this properly.
Question set 2:
Are the wider-screened dampers okay to use?
Are the smaller-screened dampers okay to use?
Where else could my problem be?
How do I know if the caps are sealing well and/or giving the ink a good prime before printing commences?
Yesterday, I ordered an entire set of new dampers and am awaiting their arrival.
I'm sorry to be long-winded, but I wanted to get as many relevant facts in as I could recall.
Any and all help and guidance is greatly appreciated.
-Bryan
Questions set 1:
Question set 2:
-Bryan
