Ink Empty - no warning!
midnightmadman
Is this a common problem with a Prismjet extra?
My black was starting to get very week in my prints and I thought maybe I had a problem. After doing some cleaning etc and no improvments I pulled out the cart. and it was completley empty! I usually get a warning message but nothing this time.
TheSnowman
Mine on my Mimaki normally goes from like oh 15% or 20% to 1% in a minute whenever it feels like it. Really annoying. Hopefully you can figure that one out.
randya
Sounds like the 'dead man' sensor.
There is a sensor that is activated by the tab that sticks out when a cartridge is empty.
MachServTech
It is generally caused by the flag not sticking out of the cartridge telling the machine it is out of ink. Usually a fault of a defective cartridge.
midnightmadman
Thanks everyone.
So the machine will just keep trying to print black and the head will run dry, correct!? I guess I better pull some ink through my waste lines?
Should I be worried?
randya
Check the cartridge and see if the tab is working properly.
If it is, then it could be the actual sensor
