Inspire Software & Chisel Fonts.
Discussion in 'General Software' started by Steve C., Jan 25, 2006.
  1. Steve C.
    Steve C. Very Active Member
    3,278
    3
    Anyone out there have any info for us about using Chisel/Multipart fonts in Inspire?
    Here is a message from Colin in another thread, incase anyone missed it. We would appriciate some help.
    Hi Steve, I thought I'd post this here in case someone else has the same problem.
    As you know I purchased the EDORAS font from you last night - thanks!
    I am having a problem though. Using your well explained tutorial, I'm finding that the bevels 1 & 2 and the face version don't match the size of the "regular" face, and therefore the kerning is way off too.
    I'm using Inspire 1.6, and there are 4 different kerning modes: Standard, Auto, Custom and None. I've tried all of these and the problem is the same.
    Any ideas? (I suspect it has to do with a slight change in the letter height, but I don't know how to remedy this).
  2. Signmiser
    Signmiser New Member
    2
    I also run Inspire (XPpro version). Type out whatever it is in the chisel font, weld>join. Ungroup & seperate, use the arrow key --> to custom space. & the inline-outline tool or path edit to change the chisel bevel. Hope this helps.
