Install new Graphtec fc9000 in Omega 5
artofacks1
Hello,
Our tech is out until Jan. 4th and I just got another Graphtec delivered to the shop. This one I want to use it with Omega 5 instead of Flexi. However, Graphtec 9000 isnt in the local list. Any insight would be appreciated.
Thanks!
Joe House
You can use the generic HPGL driver in Omega. Make sure that your plotter is set to HPGL command language.
Good luck
artofacks1
Good luck
Which HPGL do you recommend? Thanks
Are you available for paid on the phone technical support?
artofacks1
If it's not in the list, it's not supported. Different drivers etc.
Use CM4 or flexi.
I do use Flexi with our Latex printer but would like to stay away from it as much as possible for our Edge Prints.
FYI : Flexi limits the print size and in Omega it is programmed to put the cut lines in front and back of job and still gives you full width. Another reason not to print from Flexi when paired with Graphtec.
Joe House
Since we're basically talking about an unsupported plotter in that software, you're going to have to try them out and see. Also, you'll likely not be able to make it read registration marks and cut Edge jobs without the "designated driver" . But you should be able to cut vinyl only jobs.
