Jake - Advantage Signs
I did a search, and found one or two helpful things, but am still coming up short of what I need.
I am installing a 5x8' alumilite sign on a building that has a stucco/styrofoam facade over cinderblock. I did some test holes and can't see to find any studs or facing other than the cinder block...
My question is: The foam is about 1" thick, then there is approx 1" of space before I hit the block. If I use tapcons or somehting similar, should I just tighten them until my frame is tight against the foam and stop there? I assume there is some sort of framing behind the foam, but I am tentative about tightening too much for fear of crushing the foam.
