Installing 9.1 in windows 11
GrayM
Hi all, im looking, for help with a problem.
My old windows 10 computer is on its last legs so I just bought a new one to replace it. It has windows 11 naturally.
Signlab 9.1 has been working fine with windows 10, but according to Cadlnk 9.1 will not work with win11.
I contacted Cadlink for advice...
This is their reply:
"SignLab v9.1 is obsolete software, no support available.
This old software will also not work on the newer Windows OS 11, we cannot guarantee full functionality and you will have issues for the Dongle to be recognized due to not having a Dongle driver that is compatible with Win11."
Not what I wanted to hear since I was planning to retire at 75, two years away, I didn't really want the expense of an upgrade of Signlab,
9.1 has worked wonderfully since 2011.
Has anyone heard of a way of getting it to work on windows 11? Or of any workarounds?
Thanks in advance for any replies.
GrayM
Thanks lads, I was fishing for ideas here, I only got the new computer today, and had a tech guy set it up with a local account and no MS account for privacy. I have yet to install signlab with the dongle, but it will be worth a try. I will keep you posted if I succeed or fail.
SignTDF
You can install the software on Windows 11. I currently have SignLab 8.0 installed with the old dongle on my Win 11. You can also install and use the software on an old laptop with an old windows.
GrayM
Thanks for the replies, I notice that Cadlink is now under the banner of Fiery.com. does anyone k ow who they are?
I've used Sign lab for 40 years now and it has been the most solid software of any kind I have ever used.
Neil
Hi Gray, hope you're going well.
You should be able to get it to work okay.
The main issue may be you need to install the latest dongle driver.
I'll have a poke around as I reckon I have it here. I installed SL11 on my new Win 11 comp last year, but still haven't transitioned over to it yet.
I also have my SL8 running on it too.
Send me a pm with your email.
GamecockGrafx
I hope this comes through - if not, send me an email and I will forward. I just looked at my email and got an "update" from Fiery about what I think you are talking about.
Update Digital Factory & SignLab to Avoid Licensing Issues​
External
Inbox
Search for all messages with label Inbox
Remove label Inbox from this conversation
Fiery Specialty Production <noreply@cadlink.com>​
Thu, Apr 3, 12:45 PM (1 day ago)
to me
CAUTION: This email originated from outside your organization. Exercise caution when opening attachments or on clicking links from unknown senders.
Pending Windows Update Causing Licensing Issues
###LogoLights
For Digital Factory v11.3 & SignLab v11.2
If you are using a version of Digital Factory below v11.3 or SignLab below v11.2 you should update to the latest version. A pending Windows 10 or 11 update might cause licensing issues that will require support to reset your license.
To update follow the instructions below. Once updated the Windows update will not cause any issue.
For Digital Factory v10 & SignLab v10
If you are using v10 of Digital Factory or Signlab, a pending Windows 10 or 11 update might cause licensing issues that will require support to reset your license, and you must uninstall the update or the issue will recur.
To remove the Windows update, follow the instructions below.
What You Should Do
Upgrade to Digital Factory v11.3 or SignLab v11.2 to avoid a license reset. If you've already updated and are having problems, contact our support team for help.
Important note: Digital Factory v10 is no longer supported and will not receive updates or fixes. If you choose to remain on this version, you may be subject to more interruptions if the Windows update is reapplied. We encourage you to update to v11 to avoid this issue and to benefit from new features and bug fixes.
###Fierylogo
©2025 Fiery, LLC. All Rights Reserved.
ADKq_NYNOdEipuWgeJnyzNzo44z5ZThlhETJlpmFDPt-eCrhc3oxrsBQJlvdyxa7RaYyL17gcSrHm7MdfFRqo5p4txARWUgjmYTiTuvDh8578Hjv1RvveSMZ5oKeLAxSTqD0pl3LVAg_Eyo2bZVEebCVxxLj2ZrItri4QVygpULUhdegArHXze4nY_fv_jZ-VzIW0PwEYeaopkaql7ogdpzmK_Yg6xsgjGU2GyvPZVedJA4P3is8JleYwpUre3viIS6i328AO9LNlmYkNI_UEyEO4sxGRe9Zva5XjVd3WfvlHCoKJLKha6I6FEzlxqlH9sF4Zzwx3wDmfHtOk8FcHAmPWVWwfOhnNNSH1I_jX5cwLx3SV-nSlF6Oohgj50T_PQxXALI7QE1JGd_O0H1z86IGlWB_cfhUfwSO8pVnAZeIj0NTITKVbYma6BPUKYJUpj024BCwLuIluddcHFA737S4qd9QOjv4zT4Im48mdREobnFPTdr-RZYFEulLq0Xg5RmjjmCg22ZzrLTOok7JX0EroxTk9zjOJT5cC2qApahZ9t520yt0rNdnWIDupGnkOtFIpQFTr0jzyvC8rx52wNLBKL32A2kN90gdodeS5cLQ-2dIw55v3ACkQR-IvTm-ufUgCpK4C3v3F8xUTAAgmXnSTgMIX2hnxRFySdpC8zHe6mMNzKM-a6MEJZ1U1VAQXM9zXWSYQSlyhoHygF-IUIcv1o07DC94B80d2A2WQxj_hsJBeoKEGU7k1h5QOHgqjqogpxwmxuvUvetTrXrKRZmq0IiNhchnBXs3rDlBG9i-Dbz4yNlUemsa5KHhejEAqQ-i_XkzL_srdgeSdZfNMjU6faQg9E0W_f5_fqrrpFJC2gXvfLHSioYAxXXHWJFc1LWry181bpP-izyTgsKm1GmiN6p_JHw0H9t6uii3RKawpA8RbHhmYNIcMT1f7Ml6u7v6OFFmEda-3fVPJnZcd3wOUNxbWAT8ZNjN9Y0tKO8dIzuR3KawuRra6e5NJxD8WEy-M5FD0kZIlTqvAEGNh2GuGOS-BB5w4X9srUUr4rlIz9QI4VbLMo8mkqAVzngBHqwHHZjYgElUUYz2ce62lfdDbhbP-3zu6XtP9b5JM5GJGyxBJtV3kc9FdTK0SjCZMcdk0xkXMPClgExpHsKJF0o-nt8-l4DY1xIvtUp51qDbSEDG3Eg4dq2jGO2JDkgwbXVPZqdluJJEWnolBGe8DNZSD956djXK1d7FMwdriZOYMTuisCXpTg1oKY3qkgXYOC1VIGA8tlmefa3gtMeWIiy7p05YdT0ZqaoDUMyv4kjZ_ly97uFQ9QAIKU_RXv4jkSfTQO8ihpLTO7vgm8Z6XayEE1hkQknbeM_4JKarmG3losn7dVZLZ3MdXBJ-BDE9LrZylC35WltRbP21IkUYoXDq6vsVQTf_K7PIN7Mq_FY6ZONCWDjmqZKf=s0-d-e1-ft
I suggest getting a used win 10 computer from a company that fixes up and re-sells business computers. Poof you have your windows 10 backed up on a separate computer
WildWestDesigns
Depending on the specs of his Win 11 computer, may be able to run a VM of Win 10 and that way wouldn't have to have the space taken up by the second computer. Just have to do a passthru to allow hardware to be seen by the "guest".
However, as long as the system dependencies are still there, Win 11 should be able to run it. Like they said though, any update(s) could remove that ability later on (one of many reasons I don't like mandated updates and/or always connected computers, but I digress) or make it unstable.
James Burke
I've been flawlessly running SL 9.1 on Win 11 since March 2024. It installed without any issues, and I didn't have to download any special drivers.
JB
