Installing letters on Corten steel
Discussion in 'General Signmaking Topics' started by Jean Shimp, Aug 28, 2020.
  1. Jean Shimp
    Jean Shimp Member
    243
    29
    28
    Oct 26, 2012
    jacksonville, fl
    We have a job to install 10" high letters on a Corten steel wall panel. Originally we were going to use stud mounted aluminum letters but the contractor is suggesting we apply a sealant and glue the letters using APS 500 sealant instead of stud mount. This will eliminate the aluminum/steel dissimilar metals issue. Alternatively we are thinking of switching to PVC letters painted a metallic silver as they are lighter weight than metal letters. Is there any issue with the Corten oxidation interfering with the adhesive bond to the wall over time? Thanks!
  2. Rocco G
    Rocco G Member
    125
    17
    18
    Feb 27, 2014
    Pennsauken NJ
    I'll never understand the appeal of a rusty wall but it's popular now. Haven't these designers ever heard of tetanus? :p
    For 10" letters I'd use a good quality DF tape plus adhesive. The tape holds the letter while the adhesive dries. Also, then you don't have the problem with dissimilar metals touching. And someone please correct me (i'm often wrong), but isn't that really only an issue on exterior applications where water comes into play?
    • Like Like x 1
  3. Jester1167
    Jester1167 Premium Subscriber
    Gemini sell steel studs and I know you can find them elsewhere
    • Like Like x 1
  4. Moze
    Moze Precision Sign Services
    2,032
    156
    63
    Feb 27, 2012
    Dallas, TX
    The problem with Corten is it continues to weather for a period of time. That weathering process may cause issues with tape and adhesives. If it were me, I'd bite the bullet and drill the holes and sleep soundly at night.
    • Agree Agree x 2
    • Like Like x 1
    • I Appreciate You I Appreciate You x 1
  5. signbrad
    signbrad Member
    391
    191
    43
    Jun 15, 2014
    Kansas City
    Whenever I venture into uncharted waters like this, I always rely on a tested method. Stud mounting seems to be fail safe.
    If anyone here has clear-coated Corten successfully and then installed heavy letters on it using adhesive, and had it last long-term, it would be good to know. I know I haven't. That means any recommendation for adhesive mount would be pure guesswork, right? And recommending a clear coat would be a guess, too.
    I wouldn't know what clear coat would be appropriate. Matthews has no protocol for clear coating Corten.
    Corten's website even declines to give a recommendation.
    They say to ask "your paint supplier because they are the experts." That does not inspire confidence.
    They also say that if you clearcoat, "do it after it has a good patina set into the steel." Otherwise, they say, "it is very likely your clear coat will take off the rust." Huh? That doesn't inspire confidence, either.
    Stud mounting seems the safe way to install these letters.
    It's true that certain dissimilar metals have a galvanic reaction when in close contact with each other in the presence of moisture. The Corten site says to not let galvanized steel or zinc-coated steel be in contact with Corten. I would probably not let aluminum letters be in close contact, either. Of course, I don't know for sure that there would be a problem. I'm guessing on the side of caution. Therefore, I would probably not flush mount them. Nylon or rubber standoffs, even if only a quarter-inch deep, might be a good insulator, and it's easy to do.
    Will the aluminum studs react with the Corten? I don't know, but if you apply silicone to the stud by poking it all the way into the caulking tube, it will be completely coated in silicone. Would not that fix it?
    Stainless studs would not react to Corten. They might react with aluminum letters, though. Would it be a problem? I don't know, but you could dip the end of a stainless stud in silicone before you screw it into an aluminum letter. I have never put stainless studs into aluminum letters before, so I don't know if it's a problem.
    Without testing and knowing for sure, I would not attempt to clearcoat Corten and then glue letters to it, as the contractor suggested.
    However...I would not hesitate to suggest to the contractor that HE clear coat the Corten. Then I would give HIM the letters to install with his favorite adhesive. I would even make a mounting pattern for him at no charge. And I would say, "Let me know how it works out, okay?"
    Brad in Kansas City
    https://www.corten.com/frequently-asked-questions.html
    • Like Like x 2
  6. MikePro
    MikePro Major Contributor
    4,975
    235
    63
    Feb 3, 2010
    Racine, WI
    we make TONS of corten monument signs, adhering letters is silly for this purpose as stated above. Oxidizes fast and would definitely inhibit longevity of adhesion.
    +1 to securing mechanical fasteners, especially of dissimilar metals, in a gob of silicone as a "gasket" and you should be fine for a looooong time.
  7. Jean Shimp
    Jean Shimp Member
    243
    29
    28
    Oct 26, 2012
    jacksonville, fl
    Thanks for the reply. Any tips on drilling into 1/4" thick Corten - bit type? I know it will take longer than drilling into other substrates and will probably go through several bits. I'm going to add an upcharge to this quote for sure as we originally quoted installing letters to tile with adhesives.
  8. 2B
    2B Very Active Member
    3,037
    393
    83
    May 5, 2011
    TX
    • Like Like x 1
  9. MikePro
    4,975
    235
    63
    Feb 3, 2010
    Racine, WI
    its just steel....standard black/gold hss bits with wd 40 spritz's to keep from welding the bit to the corten. cleaning thoroughly afterwards so you don't get hotspots in the rust from randomly introducing oil to the surface.
    • Like Like x 1
    • Agree Agree x 1
